Turkuaz Team Mod Vti 4.1 Vu+ Duo
Kod:
First, download the latest version of the new image cihazımıza for usb installing ': (1) with the image upload to the Vu + Duo USB
Settings: after installation to be done after installation: (2) initial installation settings Vu + Duo
Quote:
Seçilidi HDMI.
1080i selected.
Language Turkish is selected.
DHCP on the network.
At this point you can call the channel list or channel can install ready.
(4) Create the favorite channel search and Vu + Duo
With four different methods to throw the Channel List (Contacts).
Quote:
TurkuazPanel Backupda Channel List from the installed.
Quote:
VU + Plus the current channel setting on the HDTV Channel Setting is loaded.
(February 8, 2012 7 Satellite: Turksat, Hellassat, Hotbird, Astra 19.2 and Astra Eurobird9 (Sirius) 4. In addition, the EPG was added to the bouquet.
@ Galaxy2002
Menu> Setup> Satellite Configuration> Settings section to come Tuner Tuner configuration.
Quote:
Tuner A: (Basic) DiSEq A / B / C / D: 42 ° / 13 / ° 7 ° / 19.2 °
Tuner B: (advanced) DisegC 1.1: 42 ° / 13 / ° 7 ° / 19.2 ° / 39 ° / 9 ° / 4.8 °
Menu => Add-ons section to come Kumandamızın Green key (Download Plug-ins) are pressed. "Plug-in information is being downloaded. Please wait ..." You will receive a message that says. On the screen after a while, "downloadable add-ons" into categories in the system. Any point to a category add-ons in that category will be listed when you press the OK button on your remote control. We press the OK button to display the categories on the kumandamızın. Here, those who installed the system will appear in green. We want we want to install or remove plug-ins one by one by pressing the OK button to select kumandamızın point. We press the red button to return to the list of categories kumandamızın. After you have selected we want to establish or remove other kategorilerdende kumandamızın we press the yellow button. We want we want to install or remove plug-ins listed. Launching the process with the green key. We press the OK button is complete when we see the text. Saying yes to the warning of the need to re-completing başalatılamsı GUI.
Quote:
Downloadable add-ons => extensions "under the cccaminfo" was established.
Downloadable add-ons => extensions "under the ecasa" was established.
Downloadable add-ons => extensions "under the enhancedmoviecenter" was established.
Downloadable add-ons => extensions "under the infobartunerstate" was established.
Downloadable add-ons => extensions "under the multiquickbutton-vu" was established.
Downloadable add-ons => extensions "under the MyTube" was established.
Downloadable add-ons => extensions "under the permanentclock" was established.
Downloadable add-ons => extensions "under the pzyemail" was established.
Downloadable add-ons => extensions under the "sherlock-vuplus" was established. Press the help button.
Downloadable add-ons => extensions "under the showclock" was established. Press the exit key long-term.
Downloadable add-ons => extensions "under the simplerss" was established. Is not active.
Downloadable add-ons => extensions "under the VLCPlayer" was established.
Downloadable add-ons => extensions "under the weatherplugin" was established.
Downloadable add-ons => extensions "under the YouTubePlayer" was founded
Downloadable add-ons => systemplugins under "positionersetup" was established.
Downloadable add-ons => systemplugins under "Satfinder" was established.
Downloadable add-ons => systemplugins under "setpsswd" was established. The password is assigned.
Downloadable add-ons => cccam2.3.0 established under the cams.
Downloadable add-ons => mgcamd1.35 established under the cams.
Downloadable add-ons => CCcam under configirations established.
Downloadable add-ons => configirations was established under the mgcamd.
I suggest that you restart your device after installing plug-ins.
Quote:
Menu => Setup => System => Time Zone: (GMT +02:00) Athens, Istanbul, Minsk
Want to install external plugins. Ipk file via ftp / tmp directory after a workout, press the blue remote, manual pull-down menu, point to the installer. Install ipkg option and press OK on your remote control, it can point to.
Quote:
Turkuazpanel_0.6_mipsel.ipk established.
Quote:
enigma2-plugin-extensions-dreamexplorer_7.3_mipsel.ipk established.
Quote:
file was edited on nStreamPlayer. @ Dursundursun
Quote:
subtitleplayer_3.11 established.
Quote:
r0_beta2 buyukbangpanel_1.1-founded.
Quote:
enigma2-plugin-founded systemplugins-bouquetsprotection_0.1_all.ipk
Quote:
VirtualZap established. Long-term press the OK button.
Quote:
startupservice established. set as the startup service: Channel D
Quote:
manager_3.0 download tunisiasat-addons-founded.
Quote:
enigma2-plugin-extensions-webmedia_5.0-r0_mipsel.ipk established.
After you restart the device on;
Quote:
Menu => Plugins => tunisiasat manager_3.0 e-addons-plugins-come first under the sport livefootball (3.4b) under the Plugins-multimedia "Netradioturk_2.6-b" is founded
Initial determination of channel:
Quote:
While the point of the channel you want to begin startup the Channel List.
Press the Menu key.
Service options in the drop-down set point as stratup press the OK button on your remote control.
Channel you want your device will restart.
If you want to cancel this process, ie if you want the latest on what channel you turned off the opening of the channel;
While the Channel List, press the Menu key.
Open the options and press OK on your remote control point to reset the startup service option.
Emu are doing the installation:
Cccam 2.3.0 downloadable add-ons, has been established.
Note: CCcam.cfg file path / etc dir. Here can edit the server with the relevant information.
1:37 Mgcamd setup:
Mgcamd_1_37.tar.gz file download / tmp folder, delivered. By pressing the blue button opening nu Kumandamızın Table VTI. Here, we press the OK button kumandamızın point to the installation manual. . Tar.gz we press the OK button on Load kumandamızın come again. In this way, making our installation.
key establishment and key updating operations installer do:
Quote:
Download hacksat-keys-downloader-e2_1.1-30102010_mipsel.rar k.ey do update.
To set up Hacksatı telnette
Code:
export MALLOC_CHECK_ = 0
ipkg install-force-overwrite / tmp / hacksat *
We give the command.
And other settings: kurulumlarımızı do.
If you want link given below and radio fund bootlogo change by taking advantage of threads:
Vu + Bootlogo replacement program, use, ready bootlogolar ...
Quote:
Değişrtirildi Bootlogo and radio fund ...
If you want to download picon file. Current HD Picon Turksat-W3 (Licher Pils +) Download the file picon the subject. Unzip the downloaded folder or folders, remove the / usr/share/enigma2 / picon folder if you have placed in the directory, or create a folder called picon into this folder will need to send the file permission after making 755.
Quote:
Picon Turksat set is loaded.
You can try different skins according to your choice: VTi-compatible interfaces
Key assignments are:
Red Short Infobar Record (Record)
Red Long Bitrateviewer
Green Short Plugin Browser (Add-on List)
Green Long Unassigned
Yellow Short Turquoise Panel
Yellow Long Unassigned
Blue Short VTi Panel
Blue Long Extension Selection
After you install the backup settings and add-ons get:
VU + 'ta get backup Duo & Solo USB and NFI
Quote:
Turquoise Backup Panel are from.
Menu> Add-ons> Turquoise panel> Backup / Restore> Full Backup HDD / USB (Vu Plus series)> Full Backup HDD
If we want to upload to the site by installing any share dosyamızı opening Backup.
Özelleştirlmiş image link in accordance with the above description to give Vu + Duo. Who want to download and install and inspect:
Examine the issues after the installation the following shortcuts:
Mount Operations vti İmajda
Good luck.
Kod:
Quote:
Seçilidi HDMI.
1080i selected.
@ Galaxy2002
Press the Menu key.
1:37 Mgcamd setup:
Code:
Good luck.
[Resimleri görebilmek için üye olun veya giriş yapın.] | This image has been resized. Click this bar to view the full image. The original image is sized 720x405. |
[Resimleri görebilmek için üye olun veya giriş yapın.] | This image has been resized. Click this bar to view the full image. The original image is sized 700x393. |
- Kod:
http://www.mediafire.com/?bozsjc0so7rz385
» Toolbox for all VU+ boxes by LSK Team v 2.0
» TooLVu+ Version 1.0 - TechSat TEAM
» Polar Team THOR Image dm500hd
