Vix 2.3 backup @isayuksel Vu Solo (Linux 3.1.1)
3.1.1)
Kod:
VIX 2.3 (Linux 3.1.1) Wu solo Image Backup @ isayuksel
Installation and initial settings::
First, download the latest version of the new image for usb installing cihazımıza: Vu + Solo USB Stick Installation Instructions for the picture
After installation to be done after the installation settings:: (2) Vu + Duo initial setup settings
Quote:
Seçilidi HDMI.
1080i is selected.
Language Turkish is selected.
DHCP on the network.
Where You can call this channel channel list or we can install ready. If you want to call channel tuner settings before you have to do.
For this review the following topic: (4) Vu + Duo channel search and bookmark create
We check the network settings using.
Menu> Setup> System> Network section of the "Network hardware settings" kumandamızın come on "OK" button is pressed.
Under the section for the current settings to take note of the IP address. (Channel settings will need to install me in the value of the rope.)
If the link I gave on the network setup problem can examine this topic: Vu + wired / wireless network setup and test procedure
4 different methods to throw the Channel List (Contacts).
Quote:
VU + Plus HDTV Channel Setting on the setting of the current channel is loaded.
(December 26, 2011 4 Satellite: Turksat, Hotbird, Astra EutelsatW3 and 19.2) was added to the EPG bouquet @ galaxy2002
Channel setting is sure to reboot after installing the device.
Menu> Setup> Satellite Configuration> Settings section came Tuner Tuner configuration.
Quote:
A tuner: (Simple) DiSEq A / B / C / D: 42 ° / 13 / ° 7 ° / 19.2 °
Note: You will notice after installing the first channel tuner ayarlamızı have made our list. Thus, because of the possible names of different satellites, satellite broadcasts, which may be taken in setting, we have prevented errors.
Add-on (plugin) installs are doing:
Menu => Plugins => Green Key (Attachment Download) A is pressed.
Extension information indiriliyor.Lütfen wait ... Extensions into categories will be displayed after a period of warning.
Quote:
Downloadable add-ons => under systemplugins Autoresolution,
Downloadable add-ons => under systemplugins setpasswd,
Downloadable add-ons => dreamexplorer under extensions (7.3),
Downloadable add-ons => MyTube under extensions,
Downloadable add-ons => permanentclock under extensions,
Downloadable add-ons => sherlock-vuplus under extensions (5.01) help button, the
Downloadable add-ons => extensions showclock under the long-term exit, press the key,
Downloadable add-ons => simplerss under extensions,
Downloadable add-ons => vlcplayer under extensions,
Downloadable add-ons => weatherplugin under extensions,
Downloadable add-ons => webinterfaceold under extensions,
Downloadable add-ons => youtubeplayer established under extensions.
Whenever you install plugins as external. Ipk file via ftp / tmp directory after a workout
Menu> Setup> VIX> IPK after seeing the file selected in Installer, but when we want to come to Kumandamızın OK button (or pressing the green button kumandamızdaki) by pressing the yes on the question while we do the installation by pressing the OK button kumandamızın.
Quote:
turkuazpanel_0.3.4_mipsel.ipk established.
Quote:
Nstreamplayer was 0.3 plugin.
Quote:
enigma2-plugin-extensions-subtitleplayer_3.10_mipsel.ipk established.
Quote:
enigma2-plugin-systemplugins-bouquetsprotection_0.1_all.ipk established
Quote:
file was edited on nStreamPlayer. @ Dursundursun
Quote:
Buyukbang panel v.1.1 beta 2 is established. (@ Exenonline)
Quote:
enigma2-plugin-extensions-enhancedmoviecenter_3.0.0_all.ipk established.
Quote:
enigma2-plugin-extensions-webmedia_4.2-r0_mipsel.ipk established.
Quote:
enigma2-plugin-extensions-pauli_7.5_all.ipk established. left / right keys on the channel - / + was appointed
Quote:
tunisiasat-addons-manager_3.0 was downloaded.
Our device after restarting;
Quote:
Menu => Plugins => tunisiasat manager_3.0 e-addons-plugins-come first under the sport livefootball (3.4b) under the Plugins-multimedia "Netradioturk_2.6-b" was founded
Quote:
Time Settings: (GMT +02:00) Athens, Istanbul, Minsk
Using Sync time: Transponder Time
set-up service is started: Channel D
Emu are doing the installation:
CCcam 2.3.0,
Mgcamd 1:37 and
MgCamd1.38 established manually.
CCcam.cfg file / etc folder is located. This file server uses the knowledge required not to enter.
key establishment and key update installer we also deal with:
Quote:
Hacksat-keys-downloader-e2_1.1-30102010_mipsel.rar download the update, do k.ey.
To set up Hacksat telnette
Code:
Export MALLOC_CHECK_ = 0
ipkg install-force-overwrite / tmp / Hacksat *
give the command.
Prepared in accordance with the above description for the backup link I give Vu + Solo. Who want to download and install and inspect:
Important Note:
Backup file before installing the first (if you have not done before installation) bootloder need to update the process. This process also imajdan be installed prior to a one-off.
After removing the image to download and install zipten solo_cfe_2.0_usb.zip file for this, such as making the installation process.
Easy come.
3.1.1)
Kod:
Quote:
Seçilidi HDMI.
1080i is selected.
CCcam 2.3.0,
Mgcamd 1:37 and
Code:
give the command.
Important Note:
Easy come.
[Resimleri görebilmek için üye olun veya giriş yapın.] | This image has been resized. Click this bar to view the full image. The original image is sized 700x393 and weights 137KB. |
[Resimleri görebilmek için üye olun veya giriş yapın.] | This image has been resized. Click this bar to view the full image. The original image is sized 700x393 and weights 192KB. |
[Resimleri görebilmek için üye olun veya giriş yapın.] | This image has been resized. Click this bar to view the full image. The original image is sized 700x393 and weights 181KB. |
[Resimleri görebilmek için üye olun veya giriş yapın.] | This image has been resized. Click this bar to view the full image. The original image is sized 700x393 and weights 153KB. |
[Resimleri görebilmek için üye olun veya giriş yapın.] | This image has been resized. Click this bar to view the full image. The original image is sized 700x393 and weights 122KB. |
[Resimleri görebilmek için üye olun veya giriş yapın.] | This image has been resized. Click this bar to view the full image. The original image is sized 700x393 and weights 198KB. |
[Resimleri görebilmek için üye olun veya giriş yapın.] | This image has been resized. Click this bar to view the full image. The original image is sized 700x393 and weights 121KB. |
[Resimleri görebilmek için üye olun veya giriş yapın.] | This image has been resized. Click this bar to view the full image. The original image is sized 700x393 and weights 190KB. |
[Resimleri görebilmek için üye olun veya giriş yapın.] | This image has been resized. Click this bar to view the full image. The original image is sized 700x393 and weights 140KB. |
- Kod:
http://www.mediafire.com/?tp1j2sn6ob0aoog
» OPEN ATV 4.1 VU+solo 2 backup by @tytus 56
» VU + solo 2 orginal backup ATV beta 4.0 USB by @tytus 56
» Vu+ Solo programlari
