» Canli MAc Izleme linki
Enigma Signal Meter 2 EmptyPaz Ekim 06, 2019 11:10 am tarafından turk9999
Enigma Signal Meter 2 EmptyC.tesi Eyl. 17, 2016 8:48 am tarafından turnurbil
» E2 Setting 7,13,19,42
Enigma Signal Meter 2 EmptyPaz Kas. 01, 2015 10:04 am tarafından codegen
Enigma Signal Meter 2 EmptyC.tesi Eyl. 26, 2015 5:57 am tarafından UCANKUS004
Enigma Signal Meter 2 EmptySalı Eyl. 22, 2015 12:43 pm tarafından yavoth
Enigma Signal Meter 2 EmptyPerş. Tem. 02, 2015 2:38 pm tarafından Admin
Enigma Signal Meter 2 EmptyÇarş. Tem. 01, 2015 10:55 pm tarafından ttys
Enigma Signal Meter 2 EmptyPaz Mart 22, 2015 1:48 am tarafından AHMCEL
Enigma Signal Meter 2 EmptyPerş. Mart 05, 2015 1:59 pm tarafından Admin
Sonuç :
Rechercher çıkıntı araştırma
Haber
Html Kodları
http://www.btgroup.com.tr/tr/
Canli Radyo
Fbml Kodları
Ekim 2019
 123456
78910111213
14151617181920
21222324252627
28293031
Takvim Takvim
Aşağa gitmek
Enigma Signal Meter 2 Empty Enigma Signal Meter 2
Mesaj tarafından Admin Bir Ptsi Ara. 19, 2011 4:31 pm
Version 0.0.7
First release of Enigma Signal Meter was quite popular, but it was
buggy, lacked support for many different Enigma 1 and Enigma 2 flavors,
had no support for multitasking, had confusing and different interface
for E1 & E2 receivers. That's why new Enigma Signal Meter - Krkadoni
Edition was born.
Description:
Fast, small, portable, simple and free application for Enigma 1 / Enigma
2 satellite receivers, build to help you align you satellite dish to
perfection.
Features:
SUPPORTS ALL currently existing Enigma1 and Enigma2 receivers and images
same simple interface used for Enigma1 and Enigma2 boxes (originally they are quite different)
full background processing (running tasks will not hang application)
small & portable (doesn't require installation and can be run from USB stick)
autoupdate (offers to update when new version is available)
voice reading of signal levels (uses default Windows voice)
signal beeping (beeps signal with frequency depending on signal level)
works remotely (just forward web port and you can connect from anywhere
Requirements
-Enigma 1 or Enigma 2 based satellite receivers with running Web interface (WebIf)
-Network connection between receiver and computer
-Windows XP or higher
-.NET Framework 3.5
-1 MB of free disk space
So far tested and working on:
- DM500
- DM500HD
- DM600
- DM7000
- DM7020
- DM7025
- DM800
- DM800SE
- DM8000
For best results when searching (faster response time):
- don't search while zapped on HD channels
- don't search while recording
- don't search while receiver's web interface is open in web browser
- don't search if you have other plugins running
- generally avoid anything that slows down your receiver
Administrator
Erkek Mesaj Sayısı : 2857
Kayıt tarihi : 03/05/11
http://uydudreambox.swedishforum.net
Sayfa başına dön Aşağa gitmek
Sayfa başına dön
