C.tesi Eyl. 17, 2016 8:48 am tarafından turnurbil
» Canli MAc Izleme linki
Perş. Kas. 19, 2015 8:42 pm tarafından fatih266
» E2 Setting 7,13,19,42
Paz Kas. 01, 2015 10:04 am tarafından codegen
C.tesi Eyl. 26, 2015 5:57 am tarafından UCANKUS004
Salı Eyl. 22, 2015 12:43 pm tarafından yavoth
Perş. Tem. 02, 2015 2:38 pm tarafından Admin
Çarş. Tem. 01, 2015 10:55 pm tarafından ttys
Paz Mart 22, 2015 1:48 am tarafından AHMCEL
Perş. Mart 05, 2015 1:59 pm tarafından Admin
Sonuç :
Rechercher çıkıntı araştırma
Haber
Html Kodları
http://www.btgroup.com.tr/tr/
Canli Radyo
Fbml Kodları
Haziran 2018
Takvim Takvim
OpenPLi-4.0-beta-800seV2
Aşağa gitmek
Mesaj tarafından Admin Bir Ptsi Haz. 30, 2014 1:03 pm
OpenPLi-4.0-beta-800seV2 #ssl88a
Finaly OpenPLi 4.0 with SIM2 SSL88a and patched 20131001 drivers.
I created the image with some code taken from OpenATV, OpenPLi has no support for the dm800seV2 !
This image is a 100% build image from OpenPLi source.
You can use the update function, but if the PLi team switches to a new driver or ssl you may end up with a non functional box (which is an easy fix).
Check the Openpli Oe Core history to be sure. You can find all Enigma2 changes here.
Please note: The image is still under development, so don't expect everything to work.
Because this image does not exist in original PLi form, this image uses an alternative feed server.
Features:
source: dailybuild
drivers: 20131001 patched
bootloader: ssl88a
Bootlogo:
standard bootlogo
Plugins:
No additional plugins installed, use the plugins menu and download with the green button.
Skins:
PLi-HD
Image flashing:
Internet Explorer (recommended)
SUNRAY-FlashUP
Powercycle after flashing
OpenPLi-4.0-beta-800seV2 #ssl88a dailybuild:
mega.co.nz #F!E1QShIyZ!JHze-4OBmTJ81-kTKiCMZg
Kod:
https://mega.co.nz/#F!E1QShIyZ!JHze-4OBmTJ81-kTKiCMZg
Yarattığın kıvılcım her şeyi yaktı Rabbim
Kaderim bana yalnız Sen’i bıraktı Rabbim
Administrator
Erkek Mesaj Sayısı : 2857
Kayıt tarihi : 03/05/11
http://uydudreambox.swedishforum.net
Sayfa başına dön Aşağa gitmek
Sayfa başına dön
