Mart 2024
1 | 2 | 3 | ||||
4 | 5 | 6 | 7 | 8 | 9 | 10 |
11 | 12 | 13 | 14 | 15 | 16 | 17 |
18 | 19 | 20 | 21 | 22 | 23 | 24 |
25 | 26 | 27 | 28 | 29 | 30 | 31 |
Black Hole 2.0.3 Hyperspace
More Flash space availableBetter performance
Great improvement of image quality in Solo2.
The codename of this image is a tribute to the past history of Black Hole series (one of the fastest ever images for the old dreamboxes).
Basically we have a new concept of image installation.
The Black Hole Speed Up is NOW INTEGRATED into the start wizard on the first configuration of the image after flashing and all applications can be enabled/disabled at the first boot configuration wizard.
You can choose to enable/disable features directly on first installation.
You can always access the Bh Speed Up panel later to enable/disable features.
With the package selection this way we can reduce the flash memory used and increase your box performance.
What is new:
NEW: kernel 3.3.8 (solo2)
NEW: Vuplus drivers:
- Fix deinterlacer problem (solo2, duo2)
- Support dual tuner blindscan (duo2, uno, ultimo)
- Fix SD video output problem when transcoding enabled (solo2)
- Enhance demux filtering (solo2)
- Support DTS-HD
- Add redundant interface to zapping mode
NEW: Greatly reduced image size due to the optimization of the building of larger packages.
NEW: Greatly improved image quality in Solo2 due to the new kernel and drivers
NEW: Better image performance (your Solo2 will fly).
Fixes and changes:
- Black Hole Speed Up integrated into start wizard.
- OpenWebif: install only pictures of your box (this will save even more flash space)
- [wlan] re-introduced RT3070 and RT2800USB drivers instead of the RT5572 issued driver
- Autoshutdown: plugin now defaults to inactive
- Fix tty0 > ttyS0 in populate-volatile.sh
Languages update:
- Czech
- Slovak
- French
- Greek
- hr
Warning: due to Kernel update and structural changes the Personal Backup of previous Black Hole images are not compatible with the 2.0.3 version.
[b][b][b]WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.[/b][/b][/b]
[b][b][b]The image MUST be installed in flash.[/b][/b][/b]
[b][b][b]Black Hole does not support images not installed in flash.[/b][/b][/b]
[b][b]This latest version of the Black Hole series has been entirely rewritten and improved in the code for maximum stability and performance.[/b][/b]
[b][b][b]Please note that of all images Black Hole now has the best epg system:[/b][/b][/b]
[b][b][b]- Integrated OpenEpg[/b][/b][/b]
[b][b][b]- Rytec dedicated epg.dat[/b][/b][/b]
[b][b][b]- New system epg.dat outside.[/b][/b][/b]
[b][b]This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.[/b][/b]
[b][b]Community members can then download it from our servers.[/b][/b]
[b][b]This feature provides other benefits such as:[/b][/b]
[b][b]Increase download speed of EPG[/b][/b]
[b][b]Download EPG from any channel[/b][/b]
[b][b]Schedule the download of EPG decoder even during standby[/b][/b]
[b][b]Users can customize the providers using Add / Remove function[/b][/b]
[b][b][b]Main functions of the buttons on the remote[/b][/b][/b]
[b][b]OK button = Skin with simple information[/b][/b]
[b][b]OK button x 2 = Extra Info Skin[/b][/b]
[b][b]Blue button = Black Hole Blue Panel[/b][/b]
[b][b]Blue button and then Red button = Black Hole Epg Panel[/b][/b]
[b][b]Blue button and then Yellow button = System Monitor Panel[/b][/b]
[b][b]Blue button long press = Extensions[/b][/b]
[b][b]Yellow button = Audio menu[/b][/b]
[b][b]Green button = Black Hole Green Panel[/b][/b]
[b][b]Green button long press = Subservices[/b][/b]
[b][b]Green button and then Red button = Fast Plugin Setup[/b][/b]
[b][b]Green button x 2 = Fast Plugin[/b][/b]
Button Red short press= access HbbTv functions
[b][b]Button Red long press= Red Panel (Parallel Universes Teleportation)[/b][/b]
[b][b][b]Addons[/b][/b][/b]
[b][b]Green button and then Yellow button takes you to:-[/b][/b]
[b][b]Dedicated server for BlackHole addons[/b][/b]
[b][b]Download and install additional packages from the Black Hole server[/b][/b]
[b][b][b]Infobar / OSD[/b][/b][/b]
[b][b]Analog Clock Gui[/b][/b]
[b][b]Channel orbital location[/b][/b]
[b][b]Advanced Tuner Info: Sr Freq Pol Fec[/b][/b]
[b][b]Signal SNR, BER[/b][/b]
[b][b]Infobar picons[/b][/b]
[b][b][b]Characteristics of BlackHole Panels[/b][/b][/b]
[b][b][b]Blue Panel[/b][/b][/b]
[b][b][b]Extra Settings[/b][/b][/b]
Black Hole Speed Up
[b][b]Black Hole Cron Manager (Manage schedules)[/b][/b]
[b][b]OSD Settings (OSD configuration)[/b][/b]
[b][b]Devices Manager[/b][/b]
[b][b]Usb Format Wizard[/b][/b]
[b][b]Kernel Modules [/b][/b][b][b]Manager[/b][/b][b][b](Kernel module operator)[/b][/b]
[b][b]Inadyn Settings (Configure Inadyn)[/b][/b]
[b][b]Swap File Settings (Configure File Swap)[/b][/b]
[b][b]Hard Disk Settings (Configure Hard Drive)[/b][/b]
[b][b]OpenVPN Panel ( OpenVPN Panel)[/b][/b]
[b][b]Samba / CIFS Panel ( Samba Panel)[/b][/b]
[b][b]NFS Server Panel ( NFS server Panel)[/b][/b]
[b][b]Telnet Panel ( Telnet Panel)[/b][/b]
[b][b]FTP Panel ( FTP Panel)[/b][/b]
[b][b]UPnP Client Djmount[/b][/b]
[b][b]UPnP Server Mediatomb[/b][/b]
[b][b]UpnP Server Minidlna[/b][/b]
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
[b][b][b]Info Panel[/b][/b][/b]
[b][b]1 - Gui Setting (Gui configurations)[/b][/b]
[b][b]2 - Service Information (information system)[/b][/b]
[b][b]3 - About (info)[/b][/b]
[b][b]Memory (Memory)[/b][/b]
[b][b]Space (capacity)[/b][/b]
[b][b]CPU (processor)[/b][/b]
[b][b]Process (process)[/b][/b]
Black Hole Speed Up
Pcsc Panel
Tuner Server
[b][b][b]EPG Panel[/b][/b][/b]
[b][b]Global settings (global settings EPG)[/b][/b]
[b][b]Setting Provider (ISP settings)[/b][/b]
[b][b][b]Green Panel[/b][/b][/b]
[b][b][b]Fast Plugin Setup (Configure quick access to your favourite plugin)[/b][/b][/b]
[b][b][b]Fast Plugin (Access your favourite plugin)[/b][/b][/b]
[b][b][b]Addons (added)[/b][/b][/b]
[b][b]Addons Download Manager (Manager for package downloading)[/b][/b]
[b][b]Online Feeds Settings update[/b][/b]
[b][b]Online Black Hole image update[/b][/b]
[b][b]Manual Install BH packges (Manual installation of Black Hole packages)[/b][/b]
[b][b]Manual Install IPK packages (Manual installation of IPK packages)[/b][/b]
[b][b]Addons Uninstall Panel (Uninstalled packages)[/b][/b]
[b][b]Black Hole Statistics (See connections, top downloads and more)[/b][/b]
Red Panel
BH Parallel Universe Teleportation
Black Hole
Avalon
Chaos
Ghost
Red Panel
Black Hole
Avalon
Chaos
Ghost
[b][b][b]Credits[/b][/b][/b]
[b][b][b]Thanks to Pedro_Newbie for Backup script[/b][/b][/b]
[b][b][b]Thanks to the group of Beta Testers.[/b][/b][/b]
[b][b][b]Thanks to Rytec for providing us with the server with all epg.dat files.[/b][/b][/b]
[b][b][b]Thanks to MaxZ4 for Integrated EPG loader.[/b][/b][/b]
[b][b][b]Thanks to Skaman for Cross EPG[/b][/b][/b]
[b][b][b]Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.[/b][/b][/b]
[b][b][b]Thanks to Reinh@rd for the file satellites.xml.[/b][/b][/b]
[b][b][b][b][b]DISCLAIMER[/b][/b][/b][/b][/b]
[b][b][b]THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.[/b][/b][/b]
[b][b][b]THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.[/b][/b][/b]
[b]LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.[/b]
[b][b][b]LICENSE (TERM OF USE)[/b][/b][/b]
[b][b][b]THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.[/b][/b][/b]
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
» Black Hole Vu+ Solo2 2.0.3 Hyperspace
» Oscam 5.9.53 + CCcam 2.1.3 for Black hole images
» VuUNO_Black Hole 2.0.3 Hyperspace_Backup_16.05.2013_KaYaCaN
